B&M mega shifter HELP NEEDED
adamforsythe
Maine
I have gone through two shift indicator cables so far. The one I have on now just bends when I go through the gears......what should I do? Have any of you had this problem before?
Check to make sure your engine ground strap is connected (or that you have one)....
W/ no ground strap, the shifter cable becomes the ground strap and welds itself together - then no shifty..!! :dunno:
Marv
