DK5
- Joined
- Jan 14, 2007
- Posts
- 1,547
- Reaction score
- 11
Hey guys
Heres my weekend project:
I'm trying to take my receiver hitch off of my '88 Blazer (project) and put it on my '90 K5. So far I've got 2 problems:
1. Removal:
i had to take the rear bumper off to get to the 2 rear bolts attached to the frame behind the gas tank. (broke 3 of the bumper bolts cause they were siezed so bad)
now i can get to all 4 bolts.. loosened them as much as I could, but now they are just freely spinning. i'm going to try to see if I can stick a vice-grip on the bolt somehow and stop it from spinning, but theres not alot of room.
I don't have alot of mechanical tools.. i might try to see if i can get my grinder in there maybe if the vice-grip idea fails. try to cut off the bolts maybe that way. what else can I use? I don't really want to rent an air chisel (or any other tools) but if thats the only option then I guess thats what i'll do. you guys have any other ideas/suggestions?
2. Installation:
The previous owner of my '90 K5 had a welded-to-frame receiver hitch but it was cut off sometime before I bought it. so I've got these drop-down plates welded to the frame rails still. looking from the rear this is what you see:
_ _
T==gas=tank==T
Hope that makes sense, the T's are the bottom of the frame rails.. its a plate welded to the center of each frame rail.
How do I cut these off and make a nice mounting surface for the stock receiver hitch on my '88? I was thinking that I might have to drop the gas tank down to get in there with my grinder. Will that work?
thx in advance
1. Removal:
2. Installation:
_ _
T==gas=tank==T
thx in advance
