b52 swap lift amount????
sandypants
spangdahlem AFB Germany
ok im starting to do the 52 in swap. im using the b52 kit. just wondering about how much lift would i get using this and 2 inch lift springs... just making sure i did my math right.:rolleyes: thanx jeff
No additional lift from the B52 brackets, approx 6"~7" of total lift from 2" lift 52" springs (same set up I have except I removed the bottom overload spring).
ok good. i got the 4in shackle flip in the rear with 2 in lift springs and doing the swap in the front with 2 in springs. using the ez ride block to relocate my axels out a bit. and doing the new shock mounts using the ford shock mounts using 5150 shocks. hope everything works out well...:D
how is the set up working for you?
I haven't driven mine yet because I'm too lazy to get the truck running but it looks good in the driveway. :D
I just saw you're at Eglin, good to have another local fella around. :thumb:
