Your Blazer must go to the gym.Got to park next to the new Chevy Blazer.View attachment 427646
Nope but there was a bunch of hard metal on the magnet. Looks like the pinion is riding the edge of the ring gear. Needs rebuilt.Dam not sure how that happened? Did you find the piece in the pumpkin?
)Did you leave the pinion angle as is?If the pattern is good that chip wouldn't scare me either. I ran a 10-bolt with some chips like that for years after I grenaded the spider gears and the ring and pinion ate it. (Clutch dumps and 10 bolts not recommended)
It’s going to go up. Drop the rear of the springs down for the flip the nose will go up.I’m wondering how much higher the pinion will be when I put my shackle flip in![]()
Oh definitely. Don’t even have 1350’s in the stock shaft. That’s good though because then I can take the stupid 1” drop out of the transfer/trans mount. As long as it doesn’t go beyond 18° from what I have heard it should oil the pinion up until that point.It’s going to go up. Drop the rear of the springs down for the flip the nose will go up.
Does this have a slip yoke 208? You’ll find the 14b pinion reaches further forward than the 10 bolt so it will probably push the shaft further into the t-case.
I’d say you are likely going to need a rework on the rear shaft.
