Im reading now that they should not be used on there. So I guess I’ll be taking them all off
U bolts usually get regular nuts but the bolt threads are cold rolled not cut, and the nut will cut through the threads and lock.I don't believe that I have ever seen lock washers on U bolts, even on semis. Only thick flat washers.
I don't know if there is a downside to having them or not.
I have reused u bolts knowing you shouldn't.Im reading now that they should not be used on there. So I guess I’ll be taking them all off
I got the diy4x platesMaybe grab some thick Ubolt plates from ORD or DIY4X. I had to use my factory ones a few times and they ended up getting bent. The aftermarket ones are way thicker.
Tractor supply is the best but I didn’t have time to drive all the way out thereHavasu Hardware on McCullough just north of smoketree. Best section in town I have found so far.
