Back In the Saddle Again
Try this, unplug the vacuum advance, and set the timing to 34 degrees at 4,000 RPM.
Then plug the vacuum advance back in and see how it runs.
You may also want to check the vacuum advance can and other items for a vacuum leak.
Also, if the carb got gummed up at all it can restrict the fuel delivery, so it can definitely change over time, especially if it sat at all.
It did sit for a while.. I’ll let you all know what I find.
The exact RPM is not critical, you just want to get it past the point it keeps climbing, the stiffer the advance springs, the higher the RPM the advance will peak. If it stops climbing at 3000, that's fine.
You just want to avoid setting the timing at 34 at 3,000 and then it climbs higher at 4000 or something.
If its still climbing at 4,000, you should use lighter springs.
I actually prefer it to peak by 2500 - 3000 RPM for performance, but that doesn't work for every application, it could cause pinging in high load low RPM scenarios.
My timing light doesn’t let me set the total timing. So I’m going to make a timing tape and get that done.
In the mean time I rebuilt my driver side wing window and put the passenger door somewhat together. Also cleaned my shop.
LMC window channels don’t fit. So reusing the OEM ones that came on the truck.
No Whistling our the passenger side wing window. Sealed up nice and tight. Also, it took me a fraction of the time to build the drivers side wing window. I did it dry. No soapy water just dry and it went together way easier.
no whistling from either window. Granted Ive only been up to 50 mph but they whistled no matter the speed before ha. I used the 1 piece rubber seals even though I have the 2 piece design. I think the 1 piece seals seal better.
The Bog Saga:
Went over to @Wes Harden place and put a timing light on it to see total timing. My initial is at 10° and total around 37°. And it’s running smooth. So we did not see a reason to adjust the timing. I could adjust my mech advance to kick in a little earlier.
We drove it so we could duplicate the symptoms, tried swapping metering rod springs to no avail.
I went home decided to take the carb apart. Opened it up and I’m not 100% certain because when I took the air horn off I could have sworn I seen the accelerator pump spring cockeyed in its orifice and when I removed the air horn it straightened out.
With the carb apart I checked float specs and everything Spec’d out perfectly. Well I cleaned the bowls really good, blew out every jet and every passage way. Put the carb back together and the bog is gone.
Pulls hard again. No hesitation. Got dang nearly broke the rear tires loose on the test run.
Cracked the NV4500 open.
1-2 Shift fork is wasted.
Looks like some gear chatter/chips on 2nd gear on the counter shaft.
What you guys think?
Replace shift fork and send it?
Or
Full rebuild?
IMG_8407.jpeg73303028671__28EA2A7D-F42D-4B28-B928-43053B62241B.jpeg73303032313__48C24D52-52C6-4884-B238-CD98A9CE00CE.jpegIMG_8413.jpegIMG_8412.jpeg
