18 on drive gear 44 on driven I thinkCan you confirm tooth count on both gears?
You need more driven gears or less drive gears to lower your speedo number.I think I need a 42 tooth driven gear
Doing the calculator you posted with 18T drive 4:10 ratio and 35 tires says I need 42T driven gear no it’s reading fastYou need more driven gears or less drive gears to lower your speedo number.
Unless I misunderstood and you're showing slower than actual?
Well sometimes you need to corroborate the results, they could have a bad formula or something you entered was wrong.Doing the calculator you posted with 18T drive 4:10 ratio and 35 tires says I need 42T driven gear no it’s reading fast
Sorry, 44+7 is 51Well sometimes you need to corroborate the results, they could have a bad formula or something you entered was wrong.
If you remove teeth from the driven gear, then you will get a full revolution earlier, that spins the speedometer cable more, faster reading.
You need more teeth per revolution, 7 to be exact.
If 53 teeth is not available you need less on the drive gear, 15 would be the best number
Just purchased the CFM Industries Heavy Duty gas tank skid.
I’m in no hurry for it. It’s almost too hot to work outside right now. So I got 3 months of just hoarding parts again lol@K5Devil I ordered a custom dash harness from Jabin a few years ago and the product is EXCELLENT, if I told you it was GM you’d believe it.
That said, his communication left a lot to be desired. He was a little slow on delivery but not horrible (6~7 weeks vs the 3 quoted). Once we got to the 3rd week I messaged him about an ETA and he wouldn’t answer. Around the end 5th week I told him I was going to dispute the charge if he didn’t at least reply, at that point he started talking again.
His product was well worth the wait / effort and I’d order from him again but I would also stay in contact with him weekly.
