I finally got my truck back on the road after a couple of months
. I did an axle swap, 10b/14bff, rear disc, new rotors, calipers, pads all the way around, DIY4X shackle flip, 4" front springs, ORD extended stainless lines. This was fun in my gravel drive way with hand tools..
I pulled it out onto the street, and everything was fine upto 15mph when I started getting a BAD driveline vibe. The vibe goes away when I let off the gas. Drove it about a block to a friends house so he could help me find the problem. Everything was running fine before the axle swap so I thought that it was something wrong with the new rear axle. We put it up on jack stands, started it and put it in gear. It seemed to be coming from the rear end but, upon further investigation, it is coming from my transfer case. Sounds like the chain is skipping teeth and when you let off of the gas and coast it sounds like the teeth on the gears aren't meshing correctly and grinding a little bit.
The transfer case was about a quart low so I topped it off and of course it didn't help.
Everything was fine when I parked it. I had it in 4x4 hi the whole time it was parked. So, what could be wrong with it?
85 K5, 305/700r4/np208
. I did an axle swap, 10b/14bff, rear disc, new rotors, calipers, pads all the way around, DIY4X shackle flip, 4" front springs, ORD extended stainless lines. This was fun in my gravel drive way with hand tools..I pulled it out onto the street, and everything was fine upto 15mph when I started getting a BAD driveline vibe. The vibe goes away when I let off the gas. Drove it about a block to a friends house so he could help me find the problem. Everything was running fine before the axle swap so I thought that it was something wrong with the new rear axle. We put it up on jack stands, started it and put it in gear. It seemed to be coming from the rear end but, upon further investigation, it is coming from my transfer case. Sounds like the chain is skipping teeth and when you let off of the gas and coast it sounds like the teeth on the gears aren't meshing correctly and grinding a little bit.
