back spacing??
muddysub
1 ton status
Staff member
Moderator
North Branch MN
right now i have stock tires and wheels on my '89 3/4 suburban. i'm about to get 36x12.50-16 swamper TSLs on 16x8s. what kinda back spacing do i have now? what do i need? would it be better to get a different back spacing to help clear the tires? oh one last thing, how much fender cuttin will i have to do?
donate to the "Build Scott's Suburban Foundation"
scott,
1989 GMC suburban 3/4t 4" lift soon to be rollin on 36" swampers, tbi350, th350, np241
Keep the same wheels. Backspacing aint gonna help you clear the tires. A SAWS-ALL will though!!!
Whats the lift size you have? That will tell you how much cutting you need to do.
"you know... the guy with the BAD A$$ spring perches!!!
<a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
only a 4" but i expected to cut my fenders. but i wanna add 1" ORD Add A Leaves on all four corners soon.
scott,
4" and 36's is where Im heading soon as I can save the money for the tires. YOu'll probably have to cut a fair amount off. But thats just from what I can see looking at mine. So yours could reguire more or less. But the lack of backspacing can cause your wheels to stick out further thus causeing more a of a clearance problem in the front. Need to stick to as close to stock as possible if not try for more backspacing.
But honestly I'd keep what you have.
