Well I changed my coolant. Here is how I did it, Im sure it was the best way, but it was the easiest.
1) Drained radiator
2) PUlled bottom rad. hose off water pump
3) Pulled top hose to thermostat
4) Pulled thermostat housing and thermo.
5) With the drain plug out, I ran a house thru the radiator for about 20minutes
6) with the thermostat and the water pump house off, I ran a house down the INtake manifold for about 20minutes. I dont know if this was a direct pass out to the bottom or not. So I may not have gotten the block totally flushed. I wasnt going to pull the plugs on the sides. Ill do that next go around.
I ended up replacing the thermostat housing, it was the org. one and it was pretty bad, it was corroded and was jus begging to start leaking.
I pulled , flushed and cleaned the overflow tank, it literally had what looked like MUD in the bottom of the tank, it was clumps of something.
Anyways, when I did all this. I put it all back together and ended up only putting 1 gal. of deminilized water and 1/2 gal. of coolant. I started it up and put Heat on. I kept an eye on it with the cap off. TO get air bubbles out. Drove it around, let it cool down and checked it, it was fine. Temp gauge read normal 195degree.
My question is, I thought this system was a 4 gal. system. Im guessing there was a bunch of water in the block left over and in the heater core?
