EBL is $500 and then into the emergency kit never to be seen again. But good point.
*Hopefully* never to be seen again. Lol
I know some have seen ECM failures, and I know they can happen, but as problems go, these ECMs are pretty darn robust.
Compared with modern vehicle PCM's, BCM's, etc., our ECM's are as antiquated as a carburetor. But that means simple, and a lot less to fail in general. Less components, less heat, less connections, and so on and so on.
I think you can probably look at the OBD1 ECM's like refrigerators from the 1950's. They were new at the time, and the manufacturers had no use history to draw from, so they are what we would consider overbuilt by today's standards, because they didn't have a clue how long they would last, or would need to last. Yes, they don't do things as efficiently, or quickly, or as well as more modern designs, but they last forever.
Nowadays we've been conditioned to pay $25-100k for a vehicle, and have problems right away. Or home appliances having a lifespan of 5 years. It didn't used to be that way, and I think the complexity of modern systems is the reason. There is just far more to fail, so there will be more failures. Your TBI ECM has (basically) one job: run the engine. And fans apparently.
