Backfiring..gimme some ideas.
AkMudr
Alaska
85 3/4ton M code block.
So in an effort to help pass an IM tomorrow I did a few things to the truck. Plugs (delco r44t) air cleaner, PCV valve, oil change. the usual ****. Idling @950, timing @4*
Hooked my smog pump back up..had to change the diverter valve. When the diverter valve took a crap earlier this year it backfired bad so I just pulled the vacuum line from it and it stopped backfiring.
Well, now its backfiring again. AIR pump is still hooked up and it does it with/without the diverter valve vacuum line hooked up.
I noticed with the air pump hooked back up I get much more of a rumble tone in the exhaust.
Possibly the choke sticking? I gave been having some issues with the choke.
Possible carbon buildup? Old plugs didnt look bad, actually looked slightly lean..wondering if Ive got a lean backfire however, I set the mixture with a vacuum gauge.
