chevyguy82
Registered Member
just finished tbi conversion. idle was too low no matter how i turn distributor. turned torx screw in tbi to raise idle. if i push the pedal to the floor, in driveway, it will backfire no matter how i turn the distributor. it seems to run it's best with the mark on balancer at very top far away from the timing tab. i have taken the distributor out and put back in several times after finding top dead center. the cap is turned to 2 oclock postion and number one starts above the screw on cap. am i missing something? also how many volts are supposed to go to idle air control. i have 12 on 2 pins.
