So got the backhoe running today. Fittings on the fuel lines are pretty old and shot so I am pretty sure it is super hard to start because of that.
Pump is still screaming at us. Fluid is aerated and foaming pretty bad. Makes it really hard to check the level.
How do you go about bleeding the hydraulics on a backhoe?
We extended and retracted all the rams several times and it got better. Drove it around and it got better. We have a couple leaks to chase.
This hoe hasn't run in several years.
Pic for the masses 76 International 3600
