Backorder Arrived
pauly383
Daddy383
Mesa , Arizona USA
Well , my package arrived , Sirius connect for Sony Decks with changer controls . Spent last night installing it :D
It is so small I was able to remove my glovebox , mount it on the a/c box , and its well hidden now that I reinstalled the glovebox . It does clear by a lot when opening and closing the door .
It needs a 12v battery for memory , just like the headunit would . So I tapped into the wire for the door locks on the passenger side since it was right there . The unit is fused itself , and has a noise loop isolator , so thats a non issue . Tried the locks with volume up and unit on , NO NOISE !!! Cleaned up some other wires too . And RE-FOUND my ESC box under there :pimp:
There ya go. Nice install. I have all my toys hidden aswell. Makes it nice when everything is hidden and out of the way.
Yeah I like things that way so I got room , as well as stealth . My sub amp is taking up residence under my pass seat .
I actually have Astro van captain chairs in my K5 , on what looks like newer K5 bases ( will get reupholstered ....SOMEDAYLOL ) .
Well I took the seat out , drilled the floor , mounted the amp first , and then reinstalled the seat .
Theres enough room to play with the settings , and take the cover off . But no way in hell its coming off the floor without removing the seat :pimp:
