Backspacing??????
codytr1
Registered Member
Collinsville,oklahoma
I am about to order 2 Eaton conversion wheels for my 1985 K5. Its has a srw 14bolt ff with a 4 inch lift and 35x14 ground hawgs on 15 inch wheels. It has drums right now, but i am going to disks later. What backspacing do i need????:dunno: :ears:
What do you mean conversion wheels. You still 6 lug up front? I ll post a link of some cheap 8 lug 15" 4 in backspacing later. When you change the front, you will have to touch up the calipers with a grinder, but I feel that the benefit will be worth it.
I bought eaton 15x10s 3 years ago from national at a local jamboree, i had them on a one ton 14 bolt and a dana 60, 3 3/8 back spacing worked perfect and the 60s calipers took little grinding and the tires didnt stick out too far...Now i have them on 39s with bushwacker flares and they are perfect and they were cheap......
