lectric80
3/4 ton status
Friday we got hit with a fairly heavy snowstorm, and since most of the roads couldn't get plowed fast enough, I had to use 4 wheel drive. I run Warn premium hubs, and I know they both locked in. Everything worked fine for a bit of a long drive, about 20 miles total, but when I got close to my house I heard a grinding noise when I tried to accelerate. It happened twice while I was attempting to start from a stop sign, and nothing moved, but it only did it while I attempted to accelerate. I pulled back on the shifter just in case, but there shouldn't have been any chance of grinding both front and rear while in 4 high, and it didn't seem to matter.
Ok, so on a 205 transfer case, is there a possibility of the shift linkage not fully engaging and causing this, or am I looking at a teardown of the TC?
I really don't want to tear down the TC right now, as I can't afford a Lomax kit. What are some other things I should be looking at?
It doesn't appear to be the input, since I can't duplicate it in 2 high, and I didn't attempt 4 low. It didn't do it for most of my trip, just a single instance, and it wasn't the only time I had some tire spinning happening.
In other words, it is a 208 shaft that measures about 32" collapsed, my 205 shaft measures about 25.5" collapsed. There is no way that extra 6.5" is going to work in my truck, my original shaft was only extended about 2" if that.
