buckmtn
Working on setting up the gears on 14 bolt ff. Bolted the ring gear to the carrier. When I get the backlash within spec on one spot and rotate it, it will either bind up or get loose as hell. Put the dial indicator on the backside of the gear at the top and it has .006-.007 runout in it. Not a real good place to check since its not a machined surface. Then I took a ruler and laid flat across the housing and as I rotated the ring gear you could see the teeth wobble in and out away from the straight edge. Brand new Yukon gears. Took the ring gear off and rotated it a couple times on the carrier but the same result. I even took it to work and buddy put it in the lathe and took light cut to true up mounting surface of ring gear, still no help. Anyone ever heard of a carrier being warped like that. I don't know what else to do except get another carrier. Thought of trying to find the low spot on it and shim between the ring gear and mounting surface. Any ideas???
Sorry for the long post.
