Correct. Push forward and down at the same time. Make sure your hinges are lubed up well.The biggest thing I worry about doing on the 73 is bending the hood. Someone told me you're supposed to push on front of the hood to close it.
Good to know the older hoods are better. I probably would do a cowl hood if mine bent.Correct. Push forward and down at the same time. Make sure your hinges are lubed up well.
Also the 73-74 hood were much better as they were designed correctly, in 75 they took out some bracing to make it bend up in a crash. So 75-80 hoods are much more prone to bending.
Or get a cowl induction hood like the cool kids.
Mine folded up just like that.Need a factory 73-74 hood, they don’t have the crease built in to collapse in a wreck.
Could be. I felt the hood was original, but the fenders were not.Wow, could it have been a replacement? I have a friend that bought a '74 Sub for parts (years ago) and the hood on it didn't have the preformed "crease" across the underside.
Are you sure? I never knew this. Next time I see a 73-74 at the junk yard I'll take a look. Interesting that they would redesign the hood only after two years.
