Hi All,
My 89' 350 TBI with about 215k miles has been having some symptoms that leads me to believe it's the fuel pump, but I figured I'd post here before attempting that not so simple part replacement.
The engine is dying often but not all the time at idle / low RPMs.
While on the freeway it will sometimes throw Code 44 for running too lean, but clear a minute or so later.
Throttle response just doesn't seem normal, especially when accelerating or going uphill.
I had recently replaced the IAC, Fuel Filter, and O2 Sensor, so I don't think they are the problem. When the truck is running OK at idle I see a very steady 7 PSI on the fuel pressure gauge.
Anything I should check out before dropping the gas tank to replace the fuel pump?
Thanks!
Thanks!
