Wunjee
So I got my Blazer home last night. Drove it home from the buddy's house where we replaced the heads. I live in an HOA so they frown upon us doing any work in our driveways..
Anyway, when the truck was parked after the previous owner smogged it, he left the tank full (it's a new tank, too) and the crappy California gas proceeded to go bad. All 28 gallons of it..
So the truck idles great, but when you give it gas it sputters and falls on it's face. It takes quite a bit of cranking to restart and even then it's not happy about it. The exhaust stinks of bad ethanol.
What's the best way to get rid of this much bad gas? I've seen other sources say "just drive it" but it doesn't feel safe considering it's died in the middle of intersections and isn't always easy to start again. And I just replaced the injectors so I don't know if putting bad gas through brand new injectors is the best idea..
Is this even a bad gas issue?
. It's also possible when getting a distributor wrong to reach the limits of where the rotor is lined up with contact in the cap and then the spark falls off quickly trying to jump a larger gap. It's also possible the guy just forgot how he did it, but if you saw 4* with the timing connector installed, that is not nearly enough advance. Curious to know what the timing reads with the connector unplugged.
