k20
3/4 ton status
Hey all, trying to figure out a problem with my 496. It has a crane hydraulic roller cam, crane roller lifters, crane gold race rockers. Anyway, there is this annoying tap from the valve train. Lets back track 8 months ago, I broke a guideplate, bent a pushrod, and chewed up a rocker, on exhaust valve of #8. Put in new parts, runs like a top. About.....3 weeks ago, I noticed a light ticking sound, pulled the valve cover and noticed that one of the rockers was a touch loose. Tightened it up, no more noise. Then approximately 2 weeks ago, I noticed it was back, pulled the valve cover, nothing seemed loose, so I re-adjusted all of the rockers. It didnt make a change. The noise is still there and its just driving me nuts.
It doesnt tick when its cold, or if it does it is very mild and I cant hear it over the exhaust. Its only once the oil gets good and hot that it does it. It lightly does it at idle, but just off idle it gets louder up until 2000rpm or so, then I cant tell if it quits or I cant hear it because of exhaust. The noise seems to be loudest on a coast down. Like if you are cruising at 50, and let off for a redlight up ahead, as the revs comes down, that is its loudest point. If you shut the truck down hot, let it sit 5 or 10 mins and fire it back up the noise is there from the second it fires.
Now today, I had it running with the valve covers off (making a nice mess btw), with a piece of 3/8" fuel hose stuck in my ear, I noticed that the noise seems to be coming from #6 exhaust valve. I tightened it and then loosened it, and it didnt make any change in the noise. So I pulled the 2 rockers for #6, the noise went away, then I swapped rockers to eliminate a bad rocker, and the noise stayed on the exhaust valve.
Now for the question, I was talking to a friend of mine and he mentioned it could also be a worn valve guide. The guides were replaced....25000 miles ago when the motor was rebuilt, of course so were the lifters. Does this sound more like a lifter problem, or more of a valve guide problem?
Thanks for the help guys.
Chris
Chris
