Once when I bought 8 AC 60G glow plugs at Autozone I noticed one wasn't an AC,despite being in an AC box--it was stamped "Wellman" brand,and I did not want one odd ball in the engine,so I brought it back and told the counterman I want all 8 to "match" and be the same brand--he gave me 3 AC's in exchange and told me "sorry for the inconvenience"..so it is possible you may not have gotten "real" AC's,but some cheap generic substitute..
I will not use Champion glow plugs either,they truly suck,they fail rapidly and swell up so bad you'll be lucky to remove them later when they do..and I've already stated how I feel about Autolite 1110's ..
Right now my truck has at least one 9G glow plug,after I discovered at least one dead 60g during the worst of last winters weather,that was all I had,so I put them in just to get by.
I had two complete sets of 9G's given to me "good used" condition,so I figured I may as well use those,I didn't feel like wasting $10 each on more 60g AC's..
..I'm hoping they wont swell up,but if they do--oh well...
I'm to the point I'm ready to go back to a gas engine or a different truck..I don't hate the 6.2 but I'm not a big fan of them either..don't like paying over $3 a gallon for diesel either..
Regarding the dual alternators--they shouldn't overpower the glow plugs if they were wired up correctly,one of the wires on the 2 prong plug is a "sensing" wire that reads the voltage,and tells the alternator regulator how much amps to put out--that should only increase during a heavy load,or when they are replenishing what you drained from the batteries right after cranking it over for a minute or so,and the regulator should maintain it well under the 14.5 volt maximum..
The glow plugs are rated at 10.5 volts to make them warm up quicker and drain less amps than if they were rated for higher voltages..
