Hey,
I'm pretty sure that my motor mounts are toast on my '79 K5, SM465. The last two runs I've ran, when the trail became rough (uphill moguls), the cross shaft has pulled out from the engine block side. I've never had this happen on my '77, although I did replace the motor mounts on it.
So...if I replace the mounts (assuming that's the problem), should I go with rubber or solid? I replaced the '77s with rubber, but I'm taking the '79 into higher flex areas.
The transmission mount(s) look ok, so I'm assuming the motor mounts are the problem.
Rich
Rich
