01maroonz71
well, i've tracked down yet another wobble in my truck...after the DW was fixed, and the square tire was taken care of...now i get a wobble/bounce that comes and goes...sometimes worse than other times. sometimes it's not there at all. so i hit my rear diff and my driveshaft with an angle finder and i found out that my diff is at 18degrees up and my shaft is at 15degrees. it is a CV shaft, so i think i need to be 2degrees under the D-shaft angle which means i need 5degree shims. now, i can only find 4 and 6degree shims on summit....so, would i rather be a degree down, or a degree up. also, will they come with bolts long enough to fit my 10leaf packs???? thanks alot!!!!
