yakmastermax
Hey all i'm sure this is a simple question. i multimetered the battery and it reads right under 13 volts. i just installed some new gauges (water, oil pressure, fuel, tach and voltmeter). i wired the volt meter positive terminal to the "bat ->" slot on the fusebox. the volt meter is also reading around 13 volts. i also just added some power steering fluid and kind of overfilled the resevoir. i'm not sure if these details are related but i thought i'd share to just give the largest picture possible. anyway, when i turn the key to ignition the starter just clicks and the dash volt meter drops down to zero or less but the engine does not turn. the car was running and starting fine just a few days ago, i put it up to take apart the rearend and do the gauges plus some leaks here and there and now it isn't starting but battery voltage is good. i even threw the battery on a charger and it drew .5 amp for a few minutes but then it stopped drawing and was full again at a full 13 volts. another quick detail: the way i wired the volt meter it is always reading the battery, key on or not. it was like that for about 48 hours before i tried to start it and it would not.
is this a bad starter? anyway to double check?
who knew, i sure did not.
