ccarley
Yeah. Here's the story.
I was driving to the store last night to get some Lagunitas Censored, and to a BBQ place to pick up a rack of ribs. Normally I'd have time to BBQ them myself, but with our new baby daughter, well, she decides when & what to do!
On the way to the store, I *thought* for only a second, "man it would be crazy if I got there, did my shopping, and the starter failed!". It was a passing thought, I have not had any starter issues up to this point.
Sure enough, I came out of the store, and I turn the key. "Click" goes the solenoid, and all the lights stay on. D'oh! I quickly grabbed the biggest ratchet I had with me (my bigger toolbox is only loaded for trips), and started beating as hard as I could on the sucker. Didn't work. I thought about using a screwdriver to hit the batt lead to the output from the solenoid, but there is so much grounding material around it that I didn't want to risk it. I now see that I don't need the pinion bumpstop, which is in the way, so that will be coming off. The output from the solenoid is as green as the statue of Liberty! I'm pretty sure replacing the whole thing will fix the problem, especially since the solenoid was clicking.
So, it sits in the grocery store parking lot at the moment. I'm headed out this morning to get a new starter.
What can I say, it's all my fault for thinking that!
Clay
Clay
) tends to shake 'em loose long enough to get home and R&R the starter. I do recommend a heatshield for the solenoid; Dorman makes one under the Motormite "Help!" brand, easy to do while you're replacing the thing.
