Bad Torque converter?
83ChevyK5Blazer
McHenry Mississippi
So I have had a knocking sound toward the back of my engine for some time now, ip pulled the engine tranny and t case yesterday and as I was draining the converter I flipped it over and the input into it was very loose and moved all over, could this cause my knock?
The noise is the stator and turbine moving around in there. These are normally held stationary by the input and stator support shaft of the trans when they are installed together. It is normal to hear them move around some when the converter is out of the trans.
