bagging and tagging????
tiger9297
Tupelo, Mississippi
I am in the process of finishing a MPFI 383 to go back in my '90 K5. I was very "ticky" in removing nuts, bolts, fasteners, etc. I cleaned, and painted everything and kept them in labled Ziplock bags. The thing is that I still have some hardware that never made it to a bag so I don't know where it came from. (I'm sure I'll find out soon enough). Anyway, I had heard somewhere that on that show American Hotrod or whatever it is, that Boyd Coddington makes those guys actually TAG and label each individual nut and bolt with a description of where it came from on the vehicle. What do you guys do to keep all this crap organized?
I usually lay it out neatly on the garage floor in the order it came off.Then I kick the parts all over the place numerous times while I'm working. I've been using this system for years, and it seems to work quite well.
I used a labeler and sometimes masking tape with marker on it.
But I took my truck(s) apart in 1999, so the labels are faded now. It was a futile effort.
That's the same system my dad uses, and one of the guys that worked for him for years just threw everything in a 5 gallon bucket. :haha:
:haha: :haha: :haha: :haha:
I used to tag stuff and use multiple coffe cans for different areas of the truck. now I have had everything apart so much I know where it goes. GM makes it easy, they only use about 3 different size bolts.
If you are putting it right back together then the method for remembering where things go is different then if it will be apart for a long time. Taking pictures or drawing diagrams helps with more involved stuff.
But If you can't figure out where a part goes then it must be some unneccessary part GM added for safety or emissions or some other crap.
That's quote material there my friend.
I recently swapped out the engine in my wifes Burb and used a cardboard box to keep parts in. Worked great until the bottom got wet. Next time I'll find a drain pan that doesnt already have something in it (the big one still has parts from my tranny swap sometime ago).
depending on what it is, I have been known to thread the bolt back in where it was taken out.
