CA Baja Shop Trailing arms
BlaZeus
The Real Mateo
Sheridan, WY
These are old school style trailing arms for a rear 4 link suspension set up. ~42" long. Includes bushings but no rod ends or jams. I can tell you which ones you will need tho and can also supply them if you want as I get cut pricing from poly performance. I bought from a guy in LA who had Baja Shop make him a new set of "newer design" trailing arms so these were the old ones off his k5 prerunner. I ran these for a couple months with no issues. They worked killer with Coilovers and are 100000% better upgrade from leaf springs. I ended up going a different route and building links for a more Ultra-4 type setup on my k5 as I wanted to be able to do Blazer Bash as well as other rock crawler trails in addition to the desert. You can run these on pretty much anything tho, if you're planning a properly set up 4 link.
$200 OBO.
