Ball joint grease zerks
MTBLAZER89
3/4 ton status
Kalispell, MT
Just put my new ball joints in my knuckle the other night (other one is getting machined /forums/images/graemlins/waytogo.gif) and I put the supplied zerk in on the bottom and was thinking there will be a clearance problem with the axle joint. My current balljoints have nothing there, and the axle joint looks pretty close. Anybody run zerks in their upper balljoints, or do I need to put in those little block off nut thingy's instead /forums/images/graemlins/thinking.gif /forums/images/graemlins/peace.gif
OK where can I get some of those nut plug thingy's?
/forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/peace.gif
On my upper ball joint, my zerk isn't coming straight out the bottom of the ball joint, it come out the side of the ball joint next to the bottom lip.
[ QUOTE ]
[/ QUOTE ] What kind are you buying. I would love to not have to take my hub assembly apart and pull the axle out to grease my uppers.
My moogs were the same way, off set zerks (reason I chose them over spicer). I guess you could VERY carefully drill out the side/shoulder of the upper balljoint and put a zerk in there for regular lubing, and just plug the centered hole. I would be a little worried about metal flakes when drilling though.
I've got Moogs with the angled zerk and it still didn't clear the axleshaft. /forums/images/graemlins/crazy.gif /forums/images/graemlins/dunno.gif
Here are mine, MOOG's with a straight zerk out the side shoulder.
Correction: I have no idea what I'm talking about. /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/ignore.gif
Sorry, I mis-read your post. /forums/images/graemlins/smirk.gif Mine don't look like that...they have the hole in the bottom of the balljoint, but the grease zerk has a 45 degree bend in it, and like I said earlier, it doesn't clear the axleshaft.
The only thing I can think of is that might be a difference between a D44 and a 10bolt /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
But yeah, like others have said, just use a zerk to grease it, then pull the zerk and cap the hole and save the zerk. Another idea is to lift the joint boot and use a needle tip on the end of your grease gun and fill up the cup /forums/images/graemlins/thumb.gif
