I know I've seen a thread about this, but what causes the upper ball joint to not make it up far enough? It seems like the bottom ball joint is too tall. I checked the joint and it is seated all the way. I dont know exactly what year the axle is, but I went with all 79 parts and the bearings are the correct size. heres some pics. and a couple of before and during
As for adjustment, I'll check that link. the chilton says to just torque it to 50 ftlb
Dont I know it
If I intended on keeping it I'd be getting the right set under it. the only thing on this truck thats NOT 1/2 ton is the back doors and VIN number
I'll take more pics, but it can clearly be seen in person that the space between the knuckle and the C is way larger at the bottom than on the side I havent pulled apart yet.
