had a wabble in the front so i finally lifted my truck to find that my lower ball joint was bad.... man what a pain in the butt that was to replace. i just decided to do my brakes while everything was apart anyways. but now it has a slight pull to the right, only sometimes when braking. a friend said it might be an alignment cause he had the same problem on a different car when the ball joint was replaced. idono though what are your guys thoughts.
