is any movement unacceptable?when i do a check [hands at 12 and 6]and give a push and a yank -i get a tiny movement-literally about 1/8 inch on each tire-good? or bad? any advice is appreciated. Thanks-
That'll tell you if the balljoints are bad. To tell if the bearings are bad, push and pull on the wheel like before, but look behind the tire up there and see if the knuckle is moving 1/8" or whether it's inside the hub.
