OK so I am back here and i am getting ready to revive an old truck that had been sitting for 6 years when it stopped running.
I need to diagnose so I need to disconnect everything and need to know what is required to run the 6.2 and what makes it not run.
I disconnected to the fuel filter and will be using a seperate container with a new inline filter to bypass old fuel and all the fuel system.
and I will be putting all new glow plugs with manual setup to bypass the glow plug system, and I will be supplying power directly to the IP.
It's an 84 so it's the round plug six point controler.
Is there any thing else I need to isolate like shut off solenoid or...
I just need to simplify the setup to find the problem.
Thanks guys, I have been away from diesels for a while so point out even the obvious.
