Bare Bones OBA
3 on the tree
gunnison colorado
After reading numerous threads, I decided to try fabbing up OBA.
This was done on the cheap. The only thing I had to buy was a couple of fittings, and 2 hose clamps. Everything else, including the V belt, came off the donor car. The air hose I found at the local dump, which is where the 20 gallon tank came from.
No pressure switch, or blowoff valve. I have a gauge on the tank, so when it gets to 100 psi, I shut the compressor off.
FYI, 2 standard hose clamps will hold at 100 psi, on a non-flared piece of tubing. The intake filter came off a busted compressor. 2 clamps and a piece of heater hose connect it to the compressor inlet.
Tomorrow, I am going to bypass the low pressure switch, so I just switch the dash control to AC to turn on the compressor.
Did you need any of those parts you sent with me Mike?
3 on the tree said:
Yep. I take er out ever once in a while, to keep things lubed.
Sounds like marriage. :D
70jimmy said:
Where did you mount the tank?
I'm not permanently mounting the tank. For wheeling, I fold the back seat forward, and use a seatbelt to hold the tank. That way, I can take the tank out, and reach almost 100 feet.
No James, I got everything I need.:D :D
