Parts stores didn't have the pins. I bought pins and bushing at the dealer. I had to cut the old pins to get the door off. Then I had to use a small pointed bar to get the old bushing out. What a pain that was. Now the hard part was to get the pin tops out of the hinge. I pounded very hard and it did not budge. So I used a die grinder with a cutting wheel and put a slice in the hinge so I can open the hinde just enough for the pin top to be tapped out. Just need to weld the hinge now. Grind the weld and get some touch up paint and good as new.
