Barnes 4wd
http://www.barnes4wd.com/product_info.php?cPath=470_126&products_id=2437
[FONT=arial,helvetica,sans-serif]This is the kit that has all the parts that we are always using in the shop for customers Single triangulated four links suspensions. This has all the parts that are made to stand up to the abuse that Rock Crawlers and Trail Rigs see and then some. The kit includes.[/FONT]
[FONT=arial,helvetica,sans-serif]1x [/FONT][FONT=arial,helvetica,sans-serif]Large Axle Truss[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Axle Link Mount Pair[/FONT][FONT=arial,helvetica,sans-serif] 0 Deg[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Truss Link Mount Brackets[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Frame Link Mount[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Adjustable Inner Frame Link Mount Pair[/FONT][FONT=arial,helvetica,sans-serif] 20 Deg[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]Chromoly 1 1/4"- 12 X 1" Heim[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]Chromoly 1 1/4"- 12 X 1" Heim[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]8 x [/FONT][FONT=arial,helvetica,sans-serif]High Misalignment Spacer - 1" to 5/8" Stainless Steel (pair)[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]1-1/4" - 12 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]1-1/4" - 12 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]This is great for the do it yourself fabricators looking do their own 4 link system, and did we mention that the kit is 5% off of our regular great prices for the items individually! If for any reason you need to exchange any of the items in the kit just let us know and we will make a kit to fit your project![/FONT]
http://www.barnes4wd.com/product_info.php?cPath=470_126&products_id=2321
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Large[/FONT][FONT=arial,helvetica,sans-serif] Axle Truss[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Frame Link Mount[/FONT][FONT=arial,helvetica,sans-serif][/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Axle Link Mount Pair[/FONT][FONT=arial,helvetica,sans-serif] 0Deg[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]Currie Enterprises 2-1/2" Forged Johnny Joint - 1-1/4"-12[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]Currie Enterprises 2-1/2" Forged Johnny Joint - 1-1/4"-12[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]1-1/4" - 12 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT][FONT=arial,helvetica,sans-serif]4 x [/FONT][FONT=arial,helvetica,sans-serif]1-1/4" - 12 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
