- Joined
- Mar 3, 2000
- Posts
- 9,124
- Reaction score
- 7,079
Good info here, I need to do some trouble shooting on mine!
Yup I’ve seen that you can do that. Decided I’m just going to leave the wiring part to the pros.you can remove the wire from the throttle body to repair. remove spacer and gasket under it. where the wires meet the TBI is rubber/plastic block the slides out of the tbi unit. this will give some room to work with
Going to check these out tomorrow. I’ll let y’all know what I find.At the back of the truck, driver's side, inside the frame rails just forward of the fuel tank will be a two wire weather pack connector. With the key on, (engine doesn't need to be running) disconnect it. Gauge should slowly move to over full. Easy first step in diagnosing gauge weirdness.
My suspicion with your temp gauge is that either the sender is bad, or its the wrong one. Not the wrong one if it has the nail head connector.
No IR temp gun or scan tool. Although I'm thinking it'd be a good investment to get one. Someone suggested this one at some point. May have been this thread or a different one. I'll clean the connection up and see if I get lucky.Do you have access to an IR temp gun? It's possible a PO put in the wrong thermostat (a 160*) or there isn't one. If you had a scantool you'd be able to see what temperature the ECM says the engine is, and if it corroborates the gauge, you'd know thermostat is the likely issue. IR temp gun should give you an idea as well.
When you say take a wire and ground the sender wire...do you literally mean stick the end of a wire into the terminal on that 2 wire connection running towards the engine? And I do this with the key on but engine not running?Next step for fuel gauge is to take a wire and ground the fuel tank sender wire at that connector. Gauge should go full empty with a good ground. If it passes that test, the problem is somewhere closer to the tank than that connector. I can't recall the color of the wire that is fuel gauge (vs fuel pump) if you search the board here I know it's been talked about. Or someone else will remember. Really shouldn't matter with the key in run to try both, as the pump won't be getting power as long as the key isn't cycled.
