So with my truck battery going dead lately, after having sat at most 4 weeks with no load (other than the ECM and radio presets/clock) typically in under 2 weeks, I started to diagnose the problem.
The amp draw just sitting is very small. Within what is considered average. Pulled fuses to make sure, didn't make appreciable difference in draw, so I figure all is good there. No stereo amp or anything else that might be drawing I can think of.
I then started watching the volt gauge as the vehicle was running at idle, and noted that the voltage would run just over 14V at times, then be under 13V at other times. Seemingly random, and not an indication of load. I never really caught it dropping in voltage, just happened to notice that the volt readings weren't staying consistent. Multimeter verifies the volt gauge is correct in it's readings.
I "rebuilt" it a few years ago, one of the parts store rebuild kits and bearings. Diode trio, voltage regulator, brushes being the main components of the kit. Battery is new within the year.
It's a 78amp alternator off of a 1985 (or '86 can't recall) Monte Carlo SS, with the partial serpentine belt. I believe this makes it a 12SI (plastic fan). I'm quite certain the belt isn't slipping, but I haven't tried tightening it up...I've assumed if the belt was slipping I'd get some noise or more noticeable/faster occurring fluctuations in voltage.
Kind of curious what exactly would cause the alternator to act this way? Failure of the regulator typically seems to cause either a no charge or overcharge condition, but this one isn't "dead". I can throw another kit in it, I'm sure cheap parts could be an issue, just curious where I should suspect the problem to lie, perhaps spending more money for a GM part this time around.
If it were me, I'd swap the alternator out with a spare, just to see if the behavior changes. That way you could at least narrow it down to the alternator, or the rest of the truck
