Desert Rat
Fetch the comfy chair
At some point down the line I will be making another bumper for another rig. I bought my Blazer one from 4x4 Iron (RIP). However, I've got a nice Millermatic and I will give it a shot doing my own. I've done basic welding in the past but small projects, repairs, etc. Now, when I go to weld the large pieces of flat metal together for the bumper, I've seen it done two ways. In some of the online welding instructions I've seen the two pieces overlapped. Say the top piece would rest on the front piece. The front piece that is butting up against the top piece might have a bit of a bevel put on it on the outside facing edge creating a small V with a grinder to help with the pooling. Then the pieces are welded front and back.
However, I've seen some folks here who have done bumpers and I noticed that the pieces were joined edge to edge, tacked, then welded all the way with a bead on the outside in the V and a bead on the inside in the V. Which way is the better way to go? I would be grinding down the outside obviously later for appearances. Does it matter which method is used? Is one stronger than the other?
