Basic Info
rustyK20
Newbie
I am considering buying a K5 Blazer. How many adults will the back seat hold? I want a seat belt for each. What is the overall width of the K5 with mirrors? Are there any significant mechanical differences between the Blazer and Jimmy? Any help with these questions would be greatly appreciated.
Blazer/Jimmy - other than cosmetic differences they are all the same except the Jimmy is better!
The back seat has two seat belts but can seat 3 close together.
The outside measurement on the fenders is about 6 ft. The mirrors add about 11 inches to each side(the lens iself is 9" long) for a total of 7.8 feet(ESTIMATED)...
Any other questions?
The Jimmy being better comment was just a personal preference...
Mike
See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
Well, I know in mine, It'll fit 2 to 3 adults comfortably in the back when I have my rear bench seat in. But I must admit, there aint too much leg room. But keep in mind, my K5 is 75'. From 73 to 77' the K5s rear bed was flat like the rear bed from a pick up truck. 78' to 91' that changed allowing more leg room for passengers. The rear bed is no longer flat but has a dip in the front half. I'm gonna have to go out and measure the width of the truck with from one mirror to the next, but I know the wheel base is 106.5" on the 73 to 91' models. No really big or major or mechanical differences between the Blazer and Jimmy. They're really the same truck. Only the cosmetics are different. Some prefer the Jimmy look and some the Blazer look. They have different trims, grill, etc. Anyways, hope that helps yah.
Boss
http://www.boss.coloradok5.com
They're pretty much the same but the Jimmy sounds dorkier. j/k
It's not what you buy, it's what you build!
Ok, here are the EXACT messurments
69-72: Wheelbase: 104 in., Overall Lenghth: 177.5 in Front/Rear Tread 64.0in./61.0 in., Overall Height: 68.5 in. With optional hardtop: 72.5 in., Width: 79.0 in., Front/Rear overhang: 33.25 in./40.25 in., Tailgate width and height:65.0 in x 19.25 in., Approach/Departure degrees: 35.2/25.0, ground clearance: front axle: 8.0 in., rear axle 8.0 in., Load space with rear seat removed or folded: 70.0 in. x 65.0 in. x 19.25 in.
73-... Wheelbase: 106.5 in., Overall Lenghth: 184.5 in Front/Rear Tread 65.75in./62.75 in., Overall Height: 69.5 in. With optional hardtop: 71.5 in., Width: 79.5 in., Front/Rear overhang: 33.5 in./44.5 in., Tailgate width and height:66.8 in x 22.0 in., Approach/Departure degrees: 31/24.0, ground clearance: front axle: 7.7 in., rear axle 8.0 in., Oil pan: 15.5 in., transfer case: 10.0 in., fuel tank 14.3in., Load space with rear seat installed: 33 in. x 50 in. x 41.6 in., Load space with rear seat removed or folded: 76.5 in. x 50 in. x 41.6 in.
These are the basic dimensions. There are very sutle changes almost every year but it would take me hours to write everything down.
K5
Hey Mike my backseat has 3 seatbelts. Is yours missing the lap belt in the center?
P.S. I agree the Jimmy is better
Rene
Same here tRusty, my Jimmy has a sholder belt on each side and a lap belt in the middle of the rear seat.
