this is some stuff i have saved for linking to others questions. hope this helps someone.
if you got better options just add them up and make this a good info thread.
not pimping summit racing but used as its fast / easy and shows prices and options avalible to you .
cooler line port in/out info http://www.tciauto.com/tc/cooler-fittings
cheep decent unit http://www.summitracing.com/parts/ATM-2640/
digital read out fancy http://www.summitracing.com/parts/ATM-6549/
then use this in the pan after you drill a hole and mount it. also good time for filter swap. http://www.summitracing.com/parts/BMM-80250/
then if you want in line go this route. http://www.summitracing.com/parts/BMM-80212/
and for ultimate option spin on filter kit with temp sensor port in the top . so you can extra fine filter your fluid and watch temps . http://www.summitracing.com/parts/BMM-80277/
there is also these nice small but vary efficent coolers from b&m
small http://www.summitracing.com/parts/BMM-70273/
med http://www.summitracing.com/parts/BMM-70266/
large http://www.summitracing.com/parts/BMM-70274/
and if you want full auto and no gauge swap out the stock cooler and put this in its place.
big cooler http://www.summitracing.com/parts/BMM-70297/
little cooler http://www.summitracing.com/parts/BMM-70298/
also you still need the stock cooler as fluid to cold is not good for the tranny also. best for cold weather area;s up in northern country . here is a nice simple temp control valve thats automatic for flow control of hot fluid to cooler. http://www.summitracing.com/parts/DER-13011/
