Sorry about the long post but I believe when asking a question it's best to give as much information as possible to make the job for the person answering the question as easy as possible. Here's the background and where I am today.
86 CUCV, was 24V. Found out resistor pack for glow plugs was bad and 24V was going to glow plugs which fried them.
Replaced all eight fried glow plugs and did 12V swap to allow me to eliminate the bad resistor pack.
Batteries won't charge. I suspect they weren't charging before the 24V swap. It was warm out a few months ago and I was able to start it a couple dozen times until the battery reserve was getting low so I put the charger on the batteries.
Now it's colder and I can only get a couple of starts out of it.
Recently had the 4 year old Interstate 950CCA batteries load tested as the Insterstate store. The guys said they both tested at 1200CCA.
Anyway, I went back, reinstalled the batteries and swapped the alternator with the other that I removed from the driver's side. Still not charging.
Last night I went back through the Roscommon directions step by step to make sure everything was done exactly by the book. It was.
Earlier this week I had the trickle charger on for a day. Had 13.1 V in the batteries right after I took the charger off. Left them a day and it settled back to 13.01 after they stabilized. So far so good.
Started it last night and it fired right up. I don't know how to specifically check an alternator for output. So all I did was put the meter on the hot terminal and ground the other. It was showing 12.28V which was also the battery voltage after I shut it off.
Now I'm suspecting the batteries again. As I said, they showed 13.01 V before turning the key. The truck was in the shop so it was warm. One cycle of the glow plugs and 2-3 seconds of cranking was all it took to start. I have a hard time believing that battery voltage could be as low as 12.28 after one easy start.
So, if you read all of that,
1) Shouldn't I see a 13.5-14V reading on the alternator hot wire when running?
2) Will it not show the charging voltage if a battery or the batteries are bad?
3) Do you agree that at a minimum I should have the batteries load tested again somewhere else and they are probably toast?
4) Is there a voltage regulator somewhere that could be bad and not let the alternator charge the batteries? This is my first diesel/GM in 20 years.
