So heres what I gots,
I have all of a sudden gots a battery drainage/charging problem. This is in my 1978 gmc truck, original 350 edelbrook carb. I am not sure what has happened but I drove the truck on sunday morning, and all was fine, went and got coffee about 2 miles up the road. Sunday afternoon, checked all the fluids for the week ahead and started it up to check tranny fluid. Then come monday morning I went to start it and I got idiot lights and a very slow crank till it started clicking. I left it alone took the vette to work. I got home monday afternoon. and It was completely dead, not even idiot lights. I jumped it with another vehicle and it started it up and ran fine. My voltage gauge was reading about 13 volts, while running, which is lower than what it normally reads. I put on the lights/fog lights and fan and the gauge dropped to alittle less than half unless I raise the rpms, then it goes to about 13 volts. I let it run for about a half hour then shut it off and let it sit untill the next afternoon. I went to start it and again, completely dead, not even idiot lights.
So what to look for ? Is there a way I can check the battery with a volt meter to see if something is drawing power with the key off ?
I am going to put the battery on a charger tonight. after it charges for a couple hours, I will disconnect the positive cable off the battery, and let it sit till tomorrow, then hook it up and see if the battery is holding a charge. Then go from there.
I will let it sit for a couple days and see what happens.
