copedrake
Registered Member
On my 85' GMC Sierra, I brought the alternator to be tested, they said it was ok. battery was tested and they said it held a charge. cleaned the connections at the battery and the alternator. there are no fuses blown and there is not any hot wiring straight to the battery.
when jumped, it charges the battery right under 14volts. turn the truck off and battery is dead....any suggestions? i have looked over the wiring that i could see to make nothing is shorted or burned... thanks for the help!
