Planning on running a bunch of electrical goodies so I want a good battery.
Do you need a good battery, a good alternator, or both?
My personal opinion anymore is that unless you are going to be running electrical with the rig off (which you should then get a very good true deep cycle battery, not even a hybrid marine one) get an alternator that has more than enough capacity for what you intend to run, and a starting battery that is about the cheapest you can find.
Looked at the Wal-mart battery that's been in my truck since I bought it, it's dated 9/11. So over 5 years, cheapest battery I could find. Truck sits outside for very long periods without being driven, with the tiny draw from an ECM and digital clock, but it's never gone flat on it's own.
A week or so ago I stupidly left the key in the run position. The battery was at less than a volt. Hooked up a 1A charger/maintainer, jumped the battery, it's now on a maintenance cycle, indicating none of the cells failed.
Edit: Update for future generations. Battery maintainer sat on the battery for a couple months after the above mistake. Started the truck up a few times, but with somewhat slow cranking. Drove it to work, parked it, came back out, drove it another 15 minutes, parked again, battery dead. 13V+ when running, it's not an alternator problem. So ~6 years out of a Walmart cheapy battery, which I abused twice, once fatally.
