battery's draining
possum70
Mebane, NC
picture.php
A while ago I hooked up some jumper cables backwards and smoke started coming from this terminal thing. :doah: I know, the picture is off 90 degrees. Tilt your head to the left. Now my battery drains. I'm assuming this is the problem. Problem is I don't know where these wires come from and I followed the one to the left to my blower unit. :dunno:
Any help would be greatly appreciated.
possum
That is the main junction block for power. There is a wire from the starter to that junction, from the junction to the alternator, then another from the junction to I believe the fuse block. Hooking battery cables up backwards probably fried the diodes in the alternator and without working diodes you will drain a battery.
Wow. That sucks.:( Any way to test that? Will testing it at Auto Zone check that?
possum
It's a junction block. Put an ohmmeter on each post and check resistance to ground. Should have infinite resistance. "0L" on most meters. But....
Look at the red wire close to the master cylinder. It looks melted to hell and back. There's a yellow splice at least that looks melted. When you pull too many amps through a wire, it doesn't melt locally. It usually smokes the whole wire. Anywhere that wire goes that touches metal where the insulation melted off will create a drain. Need to chase that wire and whatever it's connected to. Of course, that's if I'm seeing what I think I'm seeing.
Also, don't perform the first ohmmeter test, with this wire hooked up. A ground somewhere in this wire will show up as a ground at the junction block if it's connected. Remove wires > test junction block > reattach wires if good. Also try the same test on just that burnt wire while it's disconnected. If it has a low resistance to ground, it's shorting out somewhere. Look for similar damage elsewhere and repeat.
