Kenny78
Here is my install of the new Baumann Optishift controller in a 1982 K20. I got a 1995 K3500 4L80E from a junkyard.
According to internet resources, there is supposed to be a reluctor ring in 4L80E's up to 1996 (mine didn't
). Apparently during rebuilds they are prone to breakage and left out (just so you know if you do this). So I had to become creative, tear down the transmission, or find a 1990-1991 3/4 ton NP241 transfer case. Well I obviously did not want to tear into the trans (it requires complete disassembly) that I have a 30-day guarantee on and looked for a NP241 quietly while searching another way. While searching the internet I came across this http://www.jagsthatrun.com/Pages/Parts_S10-Reluctor-Diff.html. Well I called them to see if they made a ring for 1350 yokes and they do not. The reluctor ring uses 40 pulses per revolution so I needed to find a 40 tooth sprocket. I found one at my local Allied Bearing and I had to cut off the hub only to later find that Wholesale Tool sales one without a hub (make sure your sprocket is of a ferrous metal). Nothing that a plasma cutter and a dremel can't handle to cut a hole for it to mount around the yoke roughly following the "jags that run instructions" (sorry I forgot to takes pics before I installed). The sensor and jamnut details can also be found in those instructions.
Next obstacle was the throttle postion sensor. I didn't want to pay for the pre-made kit from various places. So I made my own out of scrap and an old TV cable. I used a sensor from a 1985-1991ish Z28. If you can build a bracket to swing the opposite way you can use the TPS off the same era V-6 camaro. On my used TV cable the trans side pulled off and allowed me to make it a custom length. I was concerned that drilling through the arm to attach the cable wouldn't leave enough swing so I used a brass cable stop (you feed the cable through and a bolt keeps the cable in place). I welded a cutoff bolt onto the arm and that provided me a place to put the cable stop.
Here is the TPS bracket (The wiring on the TPS is temporary I just needed it to confirm that it works)
Reluctor ring
). Apparently during rebuilds they are prone to breakage and left out (just so you know if you do this). So I had to become creative, tear down the transmission, or find a 1990-1991 3/4 ton NP241 transfer case. Well I obviously did not want to tear into the trans (it requires complete disassembly) that I have a 30-day guarantee on and looked for a NP241 quietly while searching another way. While searching the internet I came across this http://www.jagsthatrun.com/Pages/Parts_S10-Reluctor-Diff.html. Well I called them to see if they made a ring for 1350 yokes and they do not. The reluctor ring uses 40 pulses per revolution so I needed to find a 40 tooth sprocket. I found one at my local Allied Bearing and I had to cut off the hub only to later find that Wholesale Tool sales one without a hub (make sure your sprocket is of a ferrous metal). Nothing that a plasma cutter and a dremel can't handle to cut a hole for it to mount around the yoke roughly following the "jags that run instructions" (sorry I forgot to takes pics before I installed). The sensor and jamnut details can also be found in those instructions.Next obstacle was the throttle postion sensor. I didn't want to pay for the pre-made kit from various places. So I made my own out of scrap and an old TV cable. I used a sensor from a 1985-1991ish Z28. If you can build a bracket to swing the opposite way you can use the TPS off the same era V-6 camaro. On my used TV cable the trans side pulled off and allowed me to make it a custom length. I was concerned that drilling through the arm to attach the cable wouldn't leave enough swing so I used a brass cable stop (you feed the cable through and a bolt keeps the cable in place). I welded a cutoff bolt onto the arm and that provided me a place to put the cable stop.
Reluctor ring
. The TCI, Compushift, etc... are expensive and I didn't like the Gear Vendor price either. I came across Optishift and found out on a Mustang forum that they had a group buy. Long story short is that we have an optishift at an unbelievable price. Thanks Baumann
