Hey guys, need advice on removing a stuck cam from 454 BBC. Engine is out, on a stand. Already removed fuel pump pushrod. With the gear still attached, I was able to work it out maybe about 1/4", but that's about it. I can't it to budge any farther, even with the fancy handle. It doesn't even spin. I squirted some oil on the bearing journals, and can use a prybar on the bolts to work it back and forth, and even rotate it....but can't get it to free up enough to come out. Is there any way to get this thing out, without carnage....or has that train already sailed? Help!
Thanks.
Thanks.
